Remove Contest from Project
Home Forums Technical Support Remove Contest from Project
  • #1809539
    jodain
    12433xp
    Have been visited by the UHH I decided that sundancer was right (for once 🙂 ) and I should have started a new project for my Spring Clean Hobby Challenge 2023.  I’ve started a new project, but can’t delete the contest from my main project for this year.  Any thoughts on what I’m missing?
    #1809542
    44414xp
    You’re missing nothing. You can’t delete entries. Only edit them and delete text with a placeholder and remove the images.
    #1809587
    jodain
    12433xp
    @sundancer not what I meant.  I don’t want to delete an entry, I want to remove the Contest selection from the project.
    As you pointed out on the UHH I had re-badged by 2023 project as the Spring Clean Hobby Project 2023, something I’ve decided to change.  So I want to change the contest status of the project.
    #1809797
    somegeezer
    18480xp
    Change to the Spring Clean (not 2023)?
