- This topic has 5 replies, 3 voices, and was last updated 3 months, 3 weeks ago by
zoidpinhead.
Home › Forums › Technical Support › Cloudflare Project upload rejection
The Cloudflare issue is really bad at the moment. Usually I can get a Project post or update to go through by repeatedly reloading the page which gets the data package resent each time. Usually only need to do this one or twice regardless of how large the update is.
Tonight I lost the first version of the post completely and then several partial updates, even when I broke it down and tried it one image at a time. It has taken over an hour to get this one post done.
If there is a cache to clear or server to kick over that will help then please can this be done. Many thanks.
@zoidpinhead apologies for the issues you have been having with Cloudflare. If you or anyone else has any screenshots of the any Cloudflare error screens please forward them to me or alternatively send me the “Ray ID” (the ID each Cloudflare request has) which should be found at the bottom of any Cloudflare message screen.
Thanks for getting back to me about this. Tonight’s post took 5 refreshes after the initial Cloudflare failure but did got through as a whole without having to be dismantled and done one image at a time. Here’s the screenshot you asked for:
Smaller update today and no issues encountered. Thank you if you have applied the relevant virtual spanner.
I am not getting cloudflare issues, but it is taking a ridiculous amount of time to publish entries. I just tried to publish quite a large entry and it just sat there for 25 minutes or so doing nothing. So thinking that perhaps I was just trying to upload too much (if 22MB of images counts as too much), I cancelled it and then published the first paragraph of text and two images, which it seemed fine with. However, I then edited the post to try and add the second paragraph of text and two more images and it seems to have fallen over again.
Hi @tgu3 Today’s project post with initially one block of text and one image was rejected a number of times by Cloudflare. Some were almost immediate, some took a few seconds and a couple were 20-30 seconds before the failure.
Cloudflare Ray ID: 9b22c200afb0c616
Cloudflare Ray ID: 9b22c3466a54c616
Cloudflare Ray ID: 9b22c550ff6cc616
Cloudflare Ray ID: 9b22c6429ffec616
Cloudflare Ray ID: 9b22c71b4ca9c616
It went through on the 5th refresh.
