- This topic has 4 replies, 2 voices, and was last updated 7 years, 6 months ago by
mage.
Home › Forums › Technical Support › My project log and double photos
When I publish an entry on my project log here:
The pictures on each update/entry seem to double for some reason. I am not sure if it is something I am doing or if it is a programming glitch. Any help would be greatly appreciated, but no rush
The projects don’t need full HTML code, you can just insert an image with the single link, the embed codes provide two links to the image and that’s what’s happening. It’s pulling two images.
All you need is the single link to the image within the code or upload it to the projects system itself from your device.
I’ve used the single the single link before. It worked in the past and now Doesent show up normally for me in forum posts or project logs. However I will try again.
Thanks for the info ?
Thanks for the tips so far @lancorz
On Imgur I have tried going back over posts with: image link, direct link, markdown link, BBCode and LinkedBBCode and they all give me something along the lines of this:
I really want to use my imgur and not upload from my device for these project logs.
23
